1 - 20 of 38 Posts
Drag Racing Lover
Hello fellow hot rodders, I built a .030 over 350 flat top motor instead of the 327 for my '68 Impala. The motor hasn't been decked or anything just the overbore. I put my "186" camel hump heads on it that have been cut 0.010, previous owner ported to the max, on the runners anyway, 2.02/1.60 valves, screw in studs and guide plates. I'm running an Isky 284 Mega cam, 236/236 @ 050/ 0.510/0.510 lift on a 106 LSA with matching springs. I went with Doug Herbert anti pump-up lifters. Pete Jackson geardrive, TH400 with a Hughes 3500 stall and running a 3.73 gear, will be changing to a 4.10 over the winter months. After breaking the cam in I found one lifter that is bad, bleeding down very fast, so I pulled the intake, Tunnel Ram with two 1850-2 600 Holleys, and am going to replace all the lifters. Well, right after I built the 350 and put it in the car I ran across a 400SBC thats standard bore and it came with a pair of brand new, new style, Patriot Freedom heads for a super good price so I bought it. Now, i've got the intake off my 355 to put the new lifters in so my question is, do I leave the "186" heads on it or would I be able to tell a large difference by putting the aluminum Patriots on? If so, now is the time to do it lol. I haven't driven the car much at all due to the bad lifter but when I did drive it down the road, that's when the ticking started, the motor has very good power. This is my weekend toy for next year and it will be on the drag strip very little for tuning purposes and to have fun with my buddy's. My next build is gonna be the 400 for my S10 with just an RV cam and a good set of heads as it's going to be a semi daily driver. I value ya'lls knowledge alot and have done a whole lot of reading on here. Thanks
WFO
Putting new lifters on a used cam is a very iffy proposition. I'd rather you work on the lifter that's bleeding down- it might just need cleaning. More here.
There may be a lobe going bad on the cam. If that's the case, replace it NOW before it fills the engine w/ground up metal.
Drag Racing Lover
Yep lol I know. I'm gonna take the bad lifter apart and see whats going on before I put the new set in, should have said that in my post, sorry. If I do have to put the new lifters in I'm going to do the cam break-in again and keep my fingers crossed. When I first heard the ticking that's what I thought had happened, a lobe going bad. When I let the motor cool down I pulled the cover off to see if one of my locks had come loose on a rocker but it hadn't. I pulled the plugs and got that cylinder, #4, on TDC and readjusted the rocker. I looked at the plugs to see how my carb tune was, put the plugs back in and gettin ready to put the cover back on and just felt of the rocker arm, well all of them on that side, and it was very loose again. I took the rocker completely off to inspect, everything looked good, put it back on and readjusted. Went inside to eat supper, came back out to put the cover back on, felt of the rocker again and it was loose again, by loose I mean sloppy loose. So that's how I determined it was a lifter bleeding down.
Drag Racing Lover
I think the patriots would deffinatly breath a lot better than those humps. Have a look at the link below. Patriots seem to be holding there own
Eight Budget Small Block Chevy Heads Tested - Car Craft Magazine
Thanks for the link, i'll read what they have to say about them. What I'm really wondering is if they are gonna perform a whole lot better, make a difference like between night and day, or if I should just leave the humps on and use the Patriots on my 400 build.
If they are the Patriot Freedom heads 2168 with the 185cc runners they should work real well with your 355 motor. The 64cc chambers with the flat top pistons will have about 10:1 compression which is good for aluminum. I would be worried about detonation with the iron heads especially after being milled. Be sure to have the matching valve springs for your camshaft installed on the new heads. If you install new lifters get some 30w Royal Purple break-in oil. Do the cam break-in procedure for about 20-30 minutes at 2500 RPMs. When changing oil after break-in use 10w30 or 10w40 oil with the ZDDP additive and a good filter. When time come to build the 400 motor you will need a set of heads with about 210-215 intake runners.
I second that cdminter59. If you read that article you will see that the patriots made 40 more HP than the vortecs and the vortects are superior to cammel humps. If it were me Id bolt the patriots on if they have a 185cc runner.
Drag Racing Lover
Discussion Starter · #8 · (Edited)
I knew I would get some great opinions but never thought they would come this fast. Thank ya'll so much. I was kinda worried about detonation when I first put the heads on but I took a chance and am running my timing a little lower than I normally do and also raised my octane level to 102. I think I'm gonna pull the heads and go with the Patriots, which are the 64cc. 185cc., and run a set of "462" on my 400. If I found a pair of good Vortec heads, would I have to drill the steam holes in them to run em on my 400?
Drag Racing Lover
Discussion Starter · #9 ·
I have a pair of "461" heads, "041" and another pair of "186" if I don't find a good pair of Vortecs. Out of the three, which do you think would do the best on the 400 with a .030 overbore?
If your camels are ported,you better port the patriots also.The aluminum heads are lighter.with out putting them on a flow bench it just a guess.With that hydraulic cam and 600s you are limited there also. should make a tonne of mid range power
WFO
For a street engine, I would drill steam holes, but there is evidence it might not be needed.
I agree w/the others on the Patriots- use them as long as the intake runner volume isn't too large for the 355. Should be worth a good bit of power, especially lower in the rev range if the fuelies are fully ported.
Also the aluminum heads will give you a bit of a cushion against detonation since they shed heat better than iron heads plus they are probably not milled down like the fuelie heads now on it. They should let you run pump premimum w/o needing to take any total timing away. At least, try it that way because removing max power timing is the most ineffecient way of dealing w/detonation.
In case you're interested, there's a page on quench you might get some ideas from.
With the intake off,the car down for the winter,swapping on heads,your haft way there to be sure about repairing the problem.Might be best off by replacing the cam and lifters.
Drag Racing Lover
Discussion Starter · #13 ·
Thanks for your advice feller. I failed to mention that I'm going back with a dual plane and a Holley 4779-2. I've got to do a couple of motor swaps and my Impala is going to have to stay outside for a few weeks and I don't really want to have to cover the motor up, due to rain and maybe snow, and I can put the hood back on if I leave the tunnel ram off. But, it will be going back on before spring if the good Lord is willing.
Drag Racing Lover
Discussion Starter · #14 ·
Well, I think ya'll have made my decision for me, lol. The humps are coming off. I know what ya mean about taking the timing away and I don't really like it either but just trying to be safe. Man, this forum is awesome. I have messed with cars since I was just a young teenager, my father raced dirt track and taught me alot, and been a mechanic my whole working career but I have learned so much from this forum.
WFO
These heads are all similar. Prolly not a 5 hp difference between them as long as the are prepared the same. The 041 is supposed to have a little more meat under the spring seat and is "stealthy" in that it doesn't have the double hump identifier.
Pay attention to the compression ratio- a 64cc chamber on a 400 SBC w/flat tops and a tight quench can exceed 11.5:1- higher than pump gas will allow w/o detonation. A 22cc dished piston will put you at about 9.75:1, the absolute limit I would recommend using iron heads- and even then the cam has to be chosen carefully so the dynamic compression ratio isn't too high.
Calculators
Static compression ratio
*Interactive JavaScript to Calculate Engine's Compression Ratio (CR)
Dynamic compression ratio
*Dynamic CR
*United Engine & Machine Co. Incorporated
You should CC the heads to be sure that each pair are the same, and that none were milled excessively. Even if they are as cast and never been milled, the chamber volumes can vary from published figures.
WFO
Speaking for myself, I learn things on a regular basis- there are some very knowledgeable people here, for sure.
Cool that your Dad raced and took the time to teach you along the way. I also learned at my Father's knee, he knew so much. I miss him every day.
Good luck.
Drag Racing Lover
Discussion Starter · #17 ·
Calculators
*Dynamic CR
Thank you for the great info and for the links. I pulled the tunnel ram off and actually had 4 lifters that were bad, just not bleeding down as fast like that one. I checked my cam lobes and they checked good and also looked very nice and broken in by looking through the lifter bores. I used Isky cam lube on the flats of the lifters, after soaking them in 30W oil overnight, and put em in and got the Stealth intake on I'm gonna run temporarly. I had to stop as the Ala. vs LSU game was about to start, watching it now lol. I hope to get the impala finished up tomorrow and get started on the motor swaps i've got lined up. I wrapped the 400 up and plan on using it in an S10 build I plan to do soon. I will be reading about CR before I make my decision on which way to go.
WFO
Wow- 4 bad lifters. Just a word of caution: You do realize the chances are very, very good that at least a few of the cam lobes are worn abnormally. I would feel a LOT better if you'd bite the bullet now and put a new cam and lifters in it before the lobes go really bad and you get ground up cam and lifters circulated all through the engine- which can take the bearings and journals out, too. Meaning new bearings, a turned crank and a complete tear down to clean the trash out of the engine.
Here's a link to an online cam degree calculator that you can use to determine the intake closing angle. Using this in conjunction with the United Engine & Machine online DCR calculator will give a more accurate dcr than just using the generic "add 15 degrees to the duration at 050" in the dcr calculations. This gives almost identical results as the Pat Kelley calculator. Wallace Racing - Cam Degree Calculator
Drag Racing Lover
Discussion Starter · #20 ·
Well, now you got me nervous, lol. I'm pulling it back down and replacing the cam. What I mean by the 4 bad lifters is they wouldn't open the valves all the way, like they weren't getting oil and pumping up or something but they were getting oil and lots of it. I took 2 of em apart just to verify. I checked all the cam lobes with my dial indicator and they are all checking good, turned the motor over 2 revolutions. Shined a light through the lifter bores and all the lobes look like they broke in great. I just took it as a bad batch of lifters. I'm ordering a new cam this morning. I've thought, well, what would dad have done and it came to me, heck, he would have pulled the whole motor down "just to be on the safe side" as he would say, lol. I really need the space in my garage pretty quick but I also really really need the little money in my wallet not to mention wasting my parts.
1 - 20 of 38 Posts
