Basically Im concerned about performance.
I have a zz4 long block I could use but I was hoping for more from a 406.
Wasn’t that impressed with the zz4.
So here is what I have for the 406 build.
Heads? I have a nice set of 461's with 64cc chambers, 2.02/1.60 in good shape with hardened seats and drilled for 400 steam holes with screw in studs. Not the 461X
But Im concerned that they may not allow enough air in and out and that with the 64 cc chamber I may be pushing my CR for 93 octane.
I would like to use the parts I have simply because of economics but if its not going to perform then I need to make changes.
I could spring for a set of heads…Not vortec please. Something aftermarket.
Heres a list of what I have
406
Bore:4.125
12.5 cc dish piston
5.7 eagle rods with apr blots
Stock crank
Dual-plane performer intake
750 double pumper
Double timing chain and gears
Rotating assembly balanced.
Block has not been decked
Summit Racing Part Number:CCA-CL12-239-3
Hydraulic flat tappet
Duration 262/270
Lobe separation: 111 deg.
RPM Range:1,300-5,600
Intake Valve Lift 0.462 in.
Exhaust Valve Lift 0.480 in.
But I have a few sets of 1.6 / 1.5 roller rockers if needed.
Grind Number:CS X4 262H-11
Im curious about the torque and horsepower with this set up and the performance I can expect.
Built power glide
3:36 10 bolt
1966 Chevelle
Thanks.
406
Bore:4.125
12.5 cc dish piston
Stock crank
750 double pumper
Duration 262/270
Built power glide
3:36 10 bolt
1966 Chevelle
Thanks.
