Hired a welder to install a firewall and floor on my '34 Ford pickup. Got into it with him then found out the guy was clinically CRAZY. Anyway I moved out of town. Weeks later, prior to start up of the stock 350 SBC that's in the truck, I went to drain the oil as it had sat for 6 months and at least a gallon of water shot out of the oil pan, then some saturated oil. I was shocked and just sick about it. Of course the guy disappeared, either in the can or some asylum somewhere. My question is this. During the time the water was in the engine, I did not try to start it. I tried using a screwdriver on the flywheel and maybe it moved just slightly if at all. It was way too hard to turn. I like the motor and want to save it if I can. What exactly happened to the motor when water was put into it remembering that it was never started? If I can get the motor to turn at the flywheel using my brand new handy dandy Flywheel Turner ($44.95) and free it up will the motor be OK ? Can I expect to have trouble in the future ? If I can't get it to turn at the flywheel should I use the starter ? If I have to take the motor apart what/where should I look to find any damage ? Thanks a million for your help.
