Grace, what you're looking at there is the engine assembly date/suffix code and partial VIN code information. you need to find the engine casting number which will be on the drivers side, behind the head on the block just where the back of the engine bolts to the bell housing. you probably will have to get in there and look with a flashlight. it will be a 6 or 7 digit number, starting with a 3,6 or 1. get me that number and I'll tell you what you've got.grace5261 said:RH side of engine on plate says made for GMC then part # 88890529 then serial # 08447 thanks grace
