Re: Drop in
Max Keith said:
In order to install that setup, it will require removing your ring and pinion gears.
You lost me there...
Remove diff cover, remove center pin bolt, slide out center pin, push axles in and remove c-clips, remove axle shafts, turn diff till the spider gears come out, and pull out the side gears. Installation is reverse of removal.
Obviously this is for a c-clip axle but isn't much different then any other type of diff.
If we are talking about a 4-spider diff (like in a 14-bolt FF.) you would have to remove the carrier but because you will be reusing your carrier you can just put it back in where it was....but why would anyone in there right mind have a 14FF (or any other heavy duty truck axle) in a hotrod nono:
The 4-spider might be a bit more difficult but still requires no gear setup.
I have replaced spider gears on both 2 and 4 spider gear diffs using only tools that EVERY shade tree mechanic (only "special" tool I used on the 4-spider was a torque wrench) would have.
I call that drop in and this is NO DIFFERENT then something like an EZ-locker which has been installed by many people in their driveways.
Now that we have gotten that out of the way back to the question...
Has anyone seen one of these? Do they work well?
