I helped a friend install some 3.73's in his 95 mustang gt. He had 2.73's. Once done, he said there was a whine under decel only.
I set the pinion preload, used the stock .030 shim. Torqued the nut down slowly till i got to 140 ft lbs (minimum to start crushing the sleeve), then check my preload, it was 15-25 in lbs. That is what the 8.8 calls for. Also made sure the pinion depth was the same at the old gear, it was. Installed the carrier, had .012 backlash. I thought the runout looked good, but i only had a painting marker and a little grease to check it with. Any ideas?
