that depends on what roller cam you are looking for. Heads are not created equal AFR Alumium head will out do an ebay cheapy in most cases.
For a cam to work and make power in the upper end you will want more than 8.5 cr. 10 to1 with Al heads should still run on pump gas.
With the RPM's you will be running and the drifting situation of getting caught in the moment an MSD ignition with limiter would be a will good $300 insurance.
If you are looking at getting the 290hp GM parts plus crate motor there are better platforms to start with. There are threads on here about them.
As a fellow 240 driver
www.silviav8forums.com has alot of info about the swap. Most of it for the LS motors but still a useful site.
