Hello everyone,
I am in desperate need of some advice. I have moved from 600 ft elev. to 5200 ft.
My car is a 65 mustang w/ a mystery 289, and a toploader 4spd.
I bought this car a couple of years ago and haven't messed w/ anything below the valve covers. There is an RV cam in it, but I haven't the slightest clue about the details. It has a 4160 holley 600 cfm w/ a dual plain manifold and a carb spacer w/ a pcv valve that is hooked up. I have just replaced the plugs (hottest I could get) and the wires (7mm). Also just replaced the points with a pertornix igniter system.
The problem is it was running too rich, so I reduced the carb jets by 2 (now 64s in an 1850-1)--it ran too rich at 600 ft, and was puking gas at 5200 ft. I am getting 14 manifold vacuum, which was rising as I advanced the ignition--but now the vacuum housing on the distributor is hitting the radiator hose and cannot go any further. The balancer has moved; because the timing marks aren't accurate, I was adjusting it by feel/sound. Do I need to find some kind of taller aftermarket distributor, or is the problem elsewhere? Please let me know if there is any info that I can give to help--I've been searching past threads and can't find anything on this problem, so I am wondering about this one. Thanks for the help.
