Hi,
Just joined your site. My project is a 34 ford 3 window all steel. I first built it in the mid 60s in San jose Ca. and it was a daily driver untill I moved to Wa. St. in 1976. From there I let it go down hill untill it sat idle for the last 20 years. I am now in the process of rebuilding it from the frame up.
The drive train is from a 66 GTO 389 with wide ratio muncie and 355 posi. The engine is now bored 60 over and has std. 400 pistons with the 8 valve reliefs to help lower the compression. The block has also been 0 decked to help with detonation. I am running the stock 68cc heads and am hopeing to get away with 93 octane but we will see. I purchased a Maval Unisteer rack and pinion and Ididid steering column and will be making new mounts for them. So as not to make this post too long I will close for now. Jack.
