1 - 6 of 6 Posts
Any one out there have any advice on the suspension, brakes and steering for a 1936 dodge bussiness coupe? Swapped out motor, trans, drive shaft, rear end/ axle, everything else is original. Can the original be tightened up, and or adjusted to be kind of safer? Or should I swap out the front end with something new? Any ideas would help. Thanks
If you are going to change the drivetrain I highly recommend suspension to match. An independent front end with disc brakes, booster and power steering. Back would need a rear end to handle the new HP and suspension of your choice (parallel leafs, 4 bar, coilovers, air bags...etc.). Frame should be beefed up too. Can't build a house on shifting sands.
Front suspension, certainly brakes, needs to follow the rest of the drive train. Give these guys a look, good stuff, great tech support if their excellent instructions give an issue.
1 - 6 of 6 Posts
