Please help me out!
This is the first engine that I have ever built. I have a friend who is a mechanic, and he is at wits end with me asking all the questions, and I think he is not sure what to do next?
So this is the situation:
I have a 4 bolt chevy 350 (late 70 block):
I had the block & heads hot tanked an magna fluxed at a local machine shop. They needed to bore the block 30 thou over, so they (machine shop) order a rebuild kit. They needed to also turn the crank (apparently the motor ran out of oil, is the reason why I got the engine for free!!!). NEW Intake, and Camshaft, Edelbrock matching performer kit.
Now not knowing anything about rebuilding a motor before, I asked them to put the bottom end together. They installed the crank, cam and timing chain.
So know I get the block all wrapped in plastic, start building the top end together.
I put the new head gaskets down, properly torque the heads down in the proper pattern, etc...etc.
Then I put Special lube that came with the cam kit, on the bottom each of the hydraulic lifters. (I DIDN'T presoak the lifters in oil), then I placed the Brand new lifters Into the lifter through the head openings. no guide plates.
Now the rest of the assembly goes well setting up the rocker arms (mechanic friend help me with this 1/4 -3/4 turn.
Anyway... sorry for all the info:
but this is my problem:
I pre-oiled or primed the engine by using a cordless drill with a special attackement to turn the pump over. Doing this for like 5-10 minutes, turning the crank (manually) a few times. I don't get any oil up to the top of the head, up the push rods, onto the rocker arms. After about 10 minutes I get very small amount of oil at the top of the push rod coming up to the rocker arms.
Concerning my mechanic friend, we continue to install the engine in the old truck, and install distributer, starter, etc.
We get fuel right to the carb, and the start the engine, it starts in about 10 seconds, rotating the distributer cap, it runs and idles, then start to increase the idle, for CAM wear in period, but after 20 seconds, there is an alarming yet quiet, metal on metal sound (my mechanic friend tell me to kill the motor)
We still don't have oil to the top of the engine.
Please help suggestions?
1. We took the distributer out (using the drill to power the pump)We then opened the oil gallery plug? just above the timing chain cover, and we got plenty oil, and FAST.
2. Next we removed the oil sending unit (t connector) spun the drill / oil pump again. LOTS of oil!
We don't know what to do next??
btw (by the way) This machine shop is a very reputable and experienced Engine rebuilding speciality shop!
