Hey everyone I used to be a member here many years ago under a different user name. I've since lost the email address I used to register so I have a new account.
I'm having a backfire issue I can't seem to solve on my brand new SP350/357 crate engine. I'm getting the normal exhaust backlash I'd expect from short pipes but my driver side has a loud backfire out of the exhaust when I let the throttle snap shut to shift. If I keep the throttle from completely closing all the way it doesn't do it.
Engine is the GM 350/357 crate with 100 miles on it. Intake is a 3x2 setup with 2G's. Center carb is the only one with an idle circuit. Exhaust is a set of ceramic coated Speedway lakester headers with their baffles and turnouts. Trans is a GM NV3500. Ignition is brand new Pertronix distributor with their cap, rotor, wires, and external coil. Base timing is 12*as per GM but I've tried as high as 16* with no change. No vacuum advance as per GM and total timing is 32. I've tried hooking up the vacuum advance just to see and it didn't help.
I've tried almost everything I can think of at this point. Compression on all cylinders is good....180-190. Leakdown consistent on all cylinders as well so I don't think it's a ring or valve issue. I also relashed the valves on the driver side to be sure but they all ended up within about 1/4 turn of how GM had them. The engine idles at about 750 with 14 hg vacuum that varies +-1 hg...which seems to be common for this engine. I set the idle screws for max vacuum. Truck idles fairly well and runs good...pulls fine and cruises fine. Just the loud backfire on the one side.
About 2 weeks ago I found the driver side header slightly warped. I installed a set of RemFlex gaskets and thought it was sealed but still had the backfire. After doubling back again today I found that header still leaking at the flange by pushing air into the pipe with my shop vac and spraying soapy water around everything. All the welds were good but had the flange leak as well as a leak at the gasket for the turnout. I was able to carefully pull the header and bend it with my press today to within .010 of flat. I reinstalled the same Remflex gasket since it was basically new still and got no more bubbles around the header flange from the same test. Thought for sure it was sucking air and causing my backfire but it's still doing it! The leak at the turnout is so close to the exit I can't imagine that's causing it. I got frustrated and pulled the turnouts and baffles now and a lot of the cheap Speedway packing is already gone....although the side without the backfire is actually in way worse condition. I'm going to pick up new packing from a motorcycle shop tomorrow and swap which sides the baffles are in.
Besides that the plugs look good...a bit rich but I just went down from 62 jets in the center carb to 60's. I haven't really done any wide open throttle driving yet to draw from the end carbs. Rear end carb seals great and the front draws very little air when it's closed as well. I even put blockoff plates under them last week and ran it and still had the backfire. Cylinders 1 and 7 on that side have the lowest pipe temps of the entire engine at idle. From looking inside the intake those 2 ports sit furthest and highest from the center carb so I'm assuming they're getting the least fuel at idle. They pick right up when RPMs come up. Not sure if they go so lean when the throttle snaps shut that the fuel enters the pipes and ignites there? Could it be another carb jetting or idle adjustment issue?
I've been trying to solve this for 2 or 3 weeks now with no luck so any help is greatly appreciated. Sorry for the long post but wanted to get all the info in here for what I've tried. And pic of the truck just for attention. Thanks in advance!
