So, my wife convinced me that we (she) needed a second hotrod. We already have a ‘72 Nova street/strip car (emphasis strip). She said we need something we can cruise around in more often. Me being me, I was all on board. I found a very nice ‘63 Chevy II. It’s already been mini-tubed, F&R coil overs and disc brakes, new paint, strange 9” w/ 3.89 gears, subframe connectors…it just needs to be finished. The engine is actually an original OTC 1965 L84 375hp 327. However, when the previous owner started rebuilding the car, he put in a forged 383 rot assy. The fuelie heads were comp ported, Winters intake, 750DP and he put in a solid F/T “140 off road” cam (11:1CR). After looking more into this cam, I’m not a fan. The original PG was rebuilt for quite a bit of power and he put in a 8” 5400 converter
. The wiring needed to be finished up and a few (a lot) of odds & ends, details needed to be finished. While in the process of tackling these things, I have been able to convince my wife, she will not like the way this car runs & drives 😁. So now I’ve ordered AFR CNC’d 195’s, HRC 241/247 .545/.565” (.581/.603 w/ 1.6 rockers) 112lsa, all the recommended valvetrain parts to go with it. Also checked with AFR about what their spring pressures where. All is good there. Holley Stealth 4150 EFI kit, performer RPM intake (air-gap is crazy back ordered). I’ll likely add a 1/2”-1” spacer. Since it will be a cruiser, I will be ordering a TCI street fighter 700R4 and their 2800 converter (that’s the stall speed HRC recommended). The compression will still be right around 11:1, and the plan is to run 93 octane and have the Holley Stealth custom tuned. I’d imagine this will still be on the street/strip side, but should be very livable. It’s certainly a lot more tame than my ‘72 Nova. I think my expectations should be realistic at around 1.35hp/ci (515-520hp) & 1.25tq/ci (465-475tq). I figure it might spin to 6400-6600.
What’s your thoughts?
