lots of metal working tips here. Enjoy!
http://www.youtube.com/watch?v=Limytv2CdTQ
2 spot coats and 2 skim coats. It doesn't take much when you skim as long as you at least spot coat all the dents and dings first. At that point the skim is just bridging it together but that door dent was kind of big so it called for more than one skim, but I probably could have gotten it all in one skim if I sat all day and metal worked on it. For that door it took 4 hours just to get it ready for filler. Anymore time and the boss is looking at me funny.Lizer said:you made that skim coating look way too easy. I would have liked to see how big of a batch of filler you had on your pallette. Was that all a single batch or did you have to remix?
Also, do you go light on the hardener? It seems like you have a lot more "working time" than I'm accustomed to. If that is the fact, does it affect the cured strength?Lizer said:you made that skim coating look way too easy. I would have liked to see how big of a batch of filler you had on your pallette. Was that all a single batch or did you have to remix?
Thanks. Yeah, we checked it but it was cumbersome cause there's no rad support on it so someone held it up while I checked it. Didn't want to annoy the guy holding the fender so I could set up my camera. The fender was actually more out of shape. Had to put 2x4's under it and stand on it to get the right shape before finally being confident that everything was flush. I actually did mention fitting it up but it was on a clip where I start metal working the fender and I didn't want to make the video too long so it kind of made the clip irrelevent cause I wasn't showing the fender work.deadbodyman said:I usually dont watch body work vidios and actually this is the first one I watched of yours. Its pretty good,I could use a few pointers (on the vidio) .Was that a regular camera or one made just for vidios?(I really liked the fast foward) .
That dosen't seem like too bad of a shop to work in ,plenty of nice, older cars (like the 56 chebbie),One question though,how did you know if the contour of the door matched the contour of the fender? I usually trial fit the fender about 50 times to be sure ,did you just omit that part ,concentrating on the door? its an important step that should be shown so the less experianced can know how you got the right shape.....
That said you got that done pretty quick how would you like to make the whole skin yourself and not use any bondo???? Me too, if only I had that kind of talent...I'm trying though, maybe in 20 more years.
BTW,theres always a place for you to work in Augusta,Ga. if you ever find yourself around here..and maybe teach an old fart how to shoot a good vidio....
I liked it....
On that day it was 80 degrees. When it hits 90+ I try to not fill big panels. I'll usually do the spot filling and find something else to do then the next morning do my final skim coats. There's enough hardener always.S10xGN said:Also, do you go light on the hardener? It seems like you have a lot more "working time" than I'm accustomed to. If that is the fact, does it affect the cured strength?
Russ
You mean that cheap SOB wouldnt buy another fender???? I can see why you get frustrated with him...tech69 said:Thanks. Yeah, we checked it but it was cumbersome cause there's no rad support on it so someone held it up while I checked it. Didn't want to annoy the guy holding the fender so I could set up my camera. The fender was actually more out of shape. Had to put 2x4's under it and stand on it to get the right shape before finally being confident that everything was flush. I actually did mention fitting it up but it was on a clip where I start metal working the fender and I didn't want to make the video too long so it kind of made the clip irrelevent cause I wasn't showing the fender work.
the old man is on one fender and it took him the amount of time it took me to fix the fender and driver's door. About a day on each. Welding on each too. The other door was pushed in as well and had to repair kind of the same way as other door.deadbodyman said:You mean that cheap SOB wouldnt buy another fender???? I can see why you get frustrated with him...
When you figure out your hours and materials fixing that door and fender wouldn't it be cheaper to get replacements.how many hours do you have into them? I would think at least 15 hrs
I'll get the final word on the year, bud!64 Skylark with a 65 Gran Sport glove box door.It is a damn good video. The only thing I do differently would be the spreading of the filler, I go with the body lines. Of course on the top you need to go down but on the bottom it would be door long passes with the bodyline for me. But damn very nice stuff Henry.
It's a bright red w/ a tad of darkness to it.66 GS? Thanks for the pics. Looks like the same color as my 66 Special convertible.
If the dash pad goes all the way across I believe that is 65 only. but this is easily changed.I'll get the final word on the year, bud!
I'll check on that today. I think you have one perhaps?
Is there a dead giveaway as to why it's a 64?
