I'm sad to say that i found this list to late and screwed up my first project a little. i have a 1991 VW GTI that i'm setting up for SCCA racing and general screwing around. Anyway, i wanted to replace the door handles with Audi ones, which required cutting out the handle area on the door and welding in the new one. Well, on the recommendation of my neighbor, i bought a flanging tool and flanged the handle insert. i took my time welding it in, but it still warped a little, the metal basically sunk in around the weld. i've tried to get it back up to the surface, but i can't get a hammer behind it, so i tried using studs to pull it back out, but with the flange there, that area is stronger than the surrounding metal and only distorts the surroundings. so unless you guys have any suggestions, i'm just going to fill it in. with that in mind, should i use fiber glass filler or lead. the sunk in area is about 3mm deep around the cutout (about 3" by 8").
thanks,
Paul
PS. i've done my other patch panels with butt welds and hammering the weld while it's still hot, much better results.
thanks,
Paul
