Need info on getting a rear disk brake set up for this.
Would like to buy braket then add cheapo calipers/rotors but what kind. any info is good
Do you already have this axle?
If so then what is the backing plate flange pattern?
What wheel bolt pattern?
If you don't already have it use GM bolt pattern ends on the housing and use all GM parts for the brakes.
You could also use ford brakes and drill the rotors for the proper bolt pattern.
Chevy 10 Bolt drop in disk brake conversion
I have a chevy 10 bolt with the drop in ring and pinion. It has a square plate at the end of the axle the backing plate mounts to. I would like to do a junk yard disk brake conversion. What type of car / truck should I be looking for? Thanks
