I haven't posted in a while. I recently built a 383 and just installed it onto my TH350. I was so excited when it fired up the first time (after a faulty MSD 6A, but that's another story). Ready to pull it out of the driveway, when, NO GEARS. So I pushed it back to the house and now it's sitting and I'm all out of ideas. It'll go into park just fine. I made sure the shifter linkage is actually changing gears. I have put about 8-9 quarts of ATF in. Still nothing. When I swapped the engine, I did swap out the torque converter for a JEGS house brand one. I thought I made sure it was fully seated. After I bolted the bellhousing to the engine, I had to pull the torque converter out about .360" (which I believe is alright?). Just to double check as well, I unplugged the bottom transmission hose from the radiator and started it up and transmission fluid came flying out of the line, so I'm guessing the pump is still good. Am I missing something? Is there something stupid I forgot to hook back up after the swap? Thanks guys.
