Try adjustimg your lifters this way and i'm sure you will like it.Bring #1 to tdc.comp stroke.Loosen pushrods and adjust ex#1 3 4 8 in#1 2 5 7 rotate pushrod until tension is just felt on hyd.and then set to specs.on solids set with feeler gauge.Rotate 360 and set ex#2 5 6 7 in# 3 4 6 8 .No hot oily mess and it works on big and small blocks with adjustable valves.
