Hello, folks. Been a while~!
I have a 2000 Sierra 4 wheel disc truck that blew a brake line. My son is doing the work (he's built many rods, and I'm not physically capable) and after inspection, decided the best route to go is to remove the ABS stuff and replumb the brakes. So, he's all brand new line from the front, going to a T fitting and then to each front wheel. The rear is plumbed exactly the same way. He's bled these things repeatedly, but cannot get a pedal. He can pump it up to 1/2 pedal and it will hold, but after being released , the pedal with go to floor when applied again. He did notice a little movement and a couple of bubbles moving in the reservoir after pumping them. Bleed as he may, he cannot get any air from any line.
Okay, question time. Could this be a situation where he needs to install a residual check valve in the rear to maintain pedal? Also, could the MC have been damaged from repeatedly hitting the floor with the pedal?
I've seen many many hot rods built with plumbing exactly like this and they all work. We reused the MC and all the wheel cylinders, just replumbed it all without the ABS.
