Hey everyone
I have a 350 sbc in a '76 trans am. I am having a problem with starting the car. I checked for power at the batt terminal on the distributor with the key on and got 12 volts. I checked the power while cranking and had about 10 volts. I pulled a spark plug from the engine and grounded it and then cranked the engine and got no spark. I tried swapping the coil out with one I had lying around and still had no spark. :sweat: I am not sure what else to check, maybe the ignition module itself in the distributor? If so , how would I check it? Could this be a bad grounding issue? Any suggestions would be great, thanks all.
Ben
Ben
