car was down for new engine and tranny and now i have no wipers i have 3 wires at the switch with 12 volts and have 12 volts to the motor with a ground wire and less than 1/2 volt on the third wire. how do i check the motor and the switch. my guess would be the motor has gone bad but i dont have the cash to be wrong a few times.
also can i run jumper wires to the motor to just make it run to see if it works
also what voltage should i have to the third wire on the motor; power, ground, and what. i would think it's a signal wire but what should the voltage be?
i'd appriciate any help, thanks.
