I just replaced my 64 amp 10si with a 94 amp 12si alternator. I also replaced the V-belt and upgraded the size of the charge wire. The engine is a GMPP 350 with the stock '75 drive belt system.
The rebuilt 12si alternator seems to make quite a bit more noise, and I'm not sure if its just the larger cooling fan on the alternator, or if there is something wrong with it.
I get a noise that sounds like drive belt squeal when I start it up cold, but its not the belt slipping - is it bearings in the alternator? Is there anywhere I could put a little lubrication on the bearings?
It also sounds like my engine fan (HD clutch fan) is making more noise, but then I realized it might the fan on the alternator. I assume this is normal?
Thanks,
Bruce
Thanks,
Bruce
