1 - 7 of 7 Posts
· Registered
I'm installing a Sniper EFI on a BBC with Lakester headers.
Ideally, the bung for the O2 sensor will be 6-10 inches after the collector for a true reading of all cylinders, and a minimum of 18" of exhaust pipe behind the O2 sensor. (Holley specs)
I have neither with these headers.
Has anyone tried this? Will I get false readings? Maybe add a sensor extension?
Thanks guys.
· Registered
Thought it was x inches from the exhaust port....
mock it up in a discreet area on the collector w it installed on the car and standing there lookin at it. Try to hide it from view...weld bung...install. i would do more research they dont go that far down the pipe
Sent from my SM-G960U using Tapatalk
· Registered
Thanks BigMo,
I've talked to a local speedshop, he thinks the baffle will create enough back pressure to help with the oxygen reading from the outlet, and recommended welding the bung at least 2-3 inches beyond exhaust port.
I'm still researching, got a couple more calls to make.
Appreciate all the info I can get.
1 - 7 of 7 Posts
