Hi, I have a 87 F-150, and while it isnt a hot rod, you guys seem pretty smart, and maybe you could help me. I have a 302 with stock electronic ignition. I started having problems when the truck wouldn't crank, and I think I narrowed it down to an electrical problem. I wasnt getting good spark at the plugs, and wanted to see if it was the cap and rotor, or the coil, so I took off the coil to dist. wire, and held it close to the dist. center post. Funny thing happend, it cranked. But when i put the wire back on the dist. it dies. So I ended up replacing the cap, rotor, plugs and plug wires, coil, TFI module, and a friend gave me a dist. out of a running truck. Now it will crank sometimes, but runs really rough, with NO power. It won't even move the truck. But if i pull the wire off the dist. and hold it so that it arcs to the center post, the idle smooths out and runs good. Ive timed it, and the timing is with in spec. but I dont know what else to check. Anyone have ANY ideas, please. Thank you
