After lng time and efforts I now know why my 383 stroker was consuming oil at a very high rate and also know the source of a knock that could be heard around the base...I had looked long into different possibilities for the oil burning and always pushed away the basics wich were the oil rings gone...simply as that! Kind of surprising on a fresh (less than 1500 miles) rebuilt but apparently a bad choice of rings coupled with an unmatching honing grit resulted into a quart at every 250 miles....For very long I thought about the PVC sucking in oil,or used valves guides. I've tried many remedies to these supposed guilty ones like installing OEM internal baffles to aftermarket valve covers and even sending the heads for rebuilding...but the darn good old oil rings were the ones!
The last of my problems with this stroker was a knocking...dropped the pan twice,plastiguaged the bearings and what more!? Hours and hours of head scratching and creeping under or around that engine...nothing to find! Finally sent the motor to the shop and now I know: one piston slapping! It's not my intention to discredit hyper. pistons here but that's what was in the block and my machinist just don't like to see them into chevy's blocks as apparently they (the blocks)don't transfer heath in same way that ford's or chrysler's blocks do and the end result is to see more frequently piston slapping into a chevy block as the lesser expansion factor found with Hyper. pistons colaborate to this ...
I surely hope that finally someone who know what he's doing will build that motor right...another testimony as that once one has found a good machinist don't let him go!
Ron.
Ron.
