I have an oil leak at rear of enginge (sbc 350). It looks like it's from the rear valley gasket of intake manifold. I recently built the engine - about 4 weeks ago and I guess I didn't get it sealed well.
First question - kinda basic, but I've never really thought about it until now. There's about 3-4 in between the top of the block and intake manifold. There isn't any high pressure at the interface between manifold and block - just the oil draining down from heads. The question is - how does enough oil get that high with enough pressure to leak out? I can't believe the oil fills up the valley that high. Is it just that the air in engine is filled with oil mist and air moving through the leak in gasket pulls oil with it?
Second question - I have blue Felpro intake gaskets which came in an Felpro engine rebuilt gasket set. The gaskets look fine - can you reuse them?
Thanks
Ed
Thanks
Ed
