Hi,
I have a oil leak problem on my 2008 Mazda 6. I'm aware that has absolutely nothing to do with Hotrodding at all but I got great advise here in the past so I hope someone can help me with that as well:thumbup:! After getting my motor back in the car (had a bad rod and I got a used engine replaced all the bearings and so on) drove it for a couple hundred miles and its leaking out right were engine and transmission come together (2.3L I4 FWD ATX). As far as I can tell its engine oil. Looks like it, smells like it and its missing on the dip stick. I checked out the oil pan and it looks all dry so I would guess the rear main seal is the point of leakage. The seal is brand new and I added sealer all the way around the rubber face were it meets the girdle and the oil pan. I added an oil film to the sealing lip that goes over the crank shaft, Pushed the seal onto the crankshaft and tightened it down. Now I'm wondering if I did something wrong or missed something or could the oil come from some were else? Any help would be greatly appreciated!
Tomi
Tomi
