OK, SBC 350 about a '78, front right side by fuel pump, right below the fuel pump shaft channel I've got two bolt holes and the top one started pumping out oil today as I rev'ed the engine up. Now this is in my '46 Chevy Panel thats not on the road yet I just started it up to move the oil and water around a little and get warmed up, the engine is just hot wired for now, no alt or ac on it either. Is this a hole I can put a bolt in and not worry about or do I have a problem?? I've got good oil pressure, 55psi at idle.
Thanks
David
Thanks
David
