I have a 406 sbc motor with large oil pan and 485hp and torque. I had a massive blow out through an o ring in a sandwich adapter from oil cooler. I replaced the adapter and o ring. Now i have little oil leaks a few weeks later all over the place. My oil pressure is @ 85lbs at start and 72 at warm idle. Also my fuel pump was getting wet and was under the impression it was a bad fuel pump as it is hp also....and seems high with 6.5 lbs of fuel pressure/// but it is oil on top not gas..now the sandwich adapter seems to have oil running down the oil filter...so before i replace every seal and gasket could it be this high oil pressure killing me with leaks ?? :evil: any help would be greatly appreciated!!
