Hi guys,
So I f**ked it up real good. The engine oil drain plug on my 2002 concord.
The head was bad so I unscrewed it with the vice grip plier. Not having a new drain plug available I just screwed it back in with the plier. Now the next oil change, I have a new drain plug but I cant get the bad plug out! by now the screw is pretty much perfectly round from all the different tools I tried. I grounded 3 flats on it but the screw DOES NOT COME OUT! So I got me a new oil pan gasket and went ahead on Monday to take the whole oil pan of and fix it on the bench. According to my manual the pan comes right out after you take out the transmission to oil pan bracket and take off all the bolts. That was already another prime example that the Chrysler designers must not like mechanics at all or why in world would you put nuts on studs right above the engine cross member were you break you fingers to get to them. Anyhow, I got all out but not the oil pan. It gets stuck on the tranny housing. I was missing about 0.07" or so to get it by that housing. About nothing I know but enough to not make it come out. I was pushing her and prying there but with all the cast aluminum I stopped not to break anything. I just screwed it all back in and called it a day. I had the car on the ramps instead of on jacks. you think or know that this would make a difference? Any other ideas on how to get either the screw or oil pan out? Any hint will be greatly appreciated!
Thanks Guys.
Tomi
Thanks Guys.
Tomi
