okay, so everything went well for awhile until... i just got the timing right and started the newly built 383 and brought it up to 2000rpm. the engine ran fine, adjusted the timing and everything. i ran it for about 10 minutes before i noticed the water was out and it was getting hot so i shut it off. during this time the oil psi got no lower then 50 psi.(just to mention, i have a high volume oil pump.) then we started it up after it cooled this time with more water and a hose ready. what happened was the oil psi went up to about 50 on the intial start, then it began to slowly decline and i watched as it went to 20 psi at 2000rpm so i shut it. what i need is reasons why this would happen, i tried it twice and the same thing happened. it just kept going lower. there is a small oil leak in the front bottom of the timing cover but no other leaks at all.
i plan to do some trouble shooting but i wanted to see what everyone else thought.
also, when i had primed the engine it went up to 60 psi and stayed there for the good 5-10 minutes i did it. i did that like 3 times to make sure everything was lubed right.
all input would help.
thanks,
mike
thanks,
mike
