ok well i have another delema i just got done putting my motor back together and i have a loss of oil pressure when hot. motor is a 400 .30 over mild cam crank is freshly cut .10 .10 and was balanced to my pistons the pump is a new melling high volume the shaft is new cam bearings are new oil plugs are new
when i start up in the morning it goes to 60 idle driving down the road at 2k around 85. but once it warms up to about 190 hot idle it sits between 16-21
its a manual guage i have switched it with another same problem. my oil pickup is welded and sits a 3/4 of an inch from the bottom of the pan im lost i dont understand. any ideas ? my first 20 min startup i left it at 2k for 15 mins to break in the cam and ran 10-40w it did it then i noticed it on my test drive. came home saw the problem drained the oil it was a little silvery but i figured that was the rings to cylinder wall all the normal breaking in so i put my 20-50 in and a new ac delco filter and bang still does it i dont understand please help
