I got a real problem with my 406sbc, My oil pressure was reading very low as the engine warmed up. It would drop to 10psi at idle when it should be reading 30-35psi. and reaches to about 45-50 psi at 3000 when I should be reading 65psi. I replaced the oil pump with a new Milodon high pressure, high volume oil pump to see if it get better. I primed the oil pump then started the engine. Well, it did'nt work out. The oil pressure start to build up but it was struggling for the first 15-20 seconds of running the engine. When it reached about 60psi the oil pressure started to drop down to 0psi. I pulled the engine out to see what happened. I drained the oil found some tiny amount of metal filings in the oil. I removed the oil pan and found nothing.
I removed the new oil pump took it apart and impellers were in perfect condition. I removed the main bearing caps and connecting rod caps and found nothing, no scoaring marks or showing any copper. What could cause the oil pressure to go down to 0.
My oil pressure gauge works fine because I have an oil light connected and now it stays on when I started the engine for a few seconds. Anybody have any idea what is causing this problem. Thanks
BTW: Distributor and drive shaft are fine, no damage.
