1 - 20 of 20 Posts
Daily driver - 1993 Honda Civic LX, D15B7 engine. <---- :(
What are some things you can do to keep your oil pressure up when the mileage is really getting up there on a four cylinder? It's close to 200,000 miles and the oil pressure light is starting to flicker. (No it's not the oil sending unit. I changed it. And, no I haven't put an actual guage on it to see what the true pressure is.) But let's assume for this post anyway, that the motor is just wearing out.
How about a heavier weight oil? Anything else?
I put up the tools against$300
I think the risk of a pump failure from the heavier weight oil is greater than the benefit you would see from the increased oil pressure. Although 200k is not uncommen on a honda, its probably due for a rebuild. Do it before something breaks, might save you some money.
Discussion Starter #3
I agree with you, that's the long term fix. I just want to try and nurse it along as best I can in the short term.
Build it right the first time
lucas oil stabilizer!!!! i highly recommend it, the motor i had before i buitl my 383 stroker was a 1977 350 chevy 4 bolt that had 316,000 miles on it all original, it had on about 20psi oil pressure at cruise rpm and only about 5psi at idle i didnt like that at all, i went to the local auto zone picked up some lucas pored it in and va-wa-la i then had about 40psi at cruise and about 15 at idle, and it stayed liek that until i decided to build a new engine about another 1500 miles later i swear by that stuff now i even run it in my new motors !!!!! hope that works for you
Discussion Starter #5
UPDATE: For those who might learn from my experience. I drained the 5w-30 out this morning and put in 1 quart of Lucas oil stabilizer and filled it the rest of the way with Penzoil 10w-30 high mileage oil...I drove it approximately 5 miles and it basically died (Rods knocking so hard it wouldn't stay running.)
So the moral is, at least in this case, Lucas and thicker oil killed the engine. :nono:
I might try draining it again and put some 5w-30 back in just to see if she'll go again.
wow.....well srry to hear about your car man.....like i said when i used it, it was on an older v8 so i didnt know how it would do to a honda, i ran straight 40w penziol with the lucas in the 350 i would assume the honda would need a lower viscostity oil obviously..........hope you get it going again
Premium Member
For what it's worth, I only use 10-40 in my wifes acura. It has 244,000 miles on the original motor. I don't think the extra viscosity hurts anything on a high milage motor.
I have used STP and motor medic on some of my high milage stuff in the past and not had any catastrophic bearing failures.
I know if I used additives, (STP and motor medic) and if the motors quieted down they last a lot longer than if I used nothing. I ran motor medic in a 63 econoline for 3 years. The oil pressure in that van was nonexistant. Cold was 20 psi, hot was under 10. That was with the motor medic. (I finally killed that motor driving it from Las Vegas to Santa Cruz when it overheated and cracked the head.)
I've used nothing also.
I've seen 6 different cars of mine pitch rods from being worn out and abused. I had fun with a few of them.. :evil:
I would have tried the Lucas additive too.
Sometimes you buy some time , sometimes you don't. :(
Hope you have something else to drive.
Later, mikey
Discussion Starter #10
After I drained the 5w-30, added the 10w-30 high milage, and Lucas, the oil light was on solid. No off, on, off, and no flickering. LIke I said, it took about 5 miles and she was knocking pretty good. It just couldn't pump the thicker stuff.
As far as the history of the car I've had it for a little over a year. I did however, get it from the original owner. I don't think he took as great of care of it as maybe he should have, huh?
Oh well, live and learn. I'll see if putting something thinner back in can at least get it going again. But, if I don't thats OK. When it died I went to the Honda Dealer yesterday afternoon and bought a brand new 2007 Honda Civic Sedan with 18 miles on it. :thumbup:
I've there is compression, spark and air it should at least try to crank. I think a compression and leak down test are in order. At least thats where I would start. The vtec motors are worth a little money. If the motor is shot, part it out and put the money into suping up the new ride. JDM parts are expensive, and with the tuner market you may be able to get some good money on ebay.
Oil additives are supposed to be added slowly to a warm running engine. If you put the additive in first, you have the equivalent of 100 weight oil laying on the bottom of the pan. :)
Well maybe thats what happened, the heavier weight oil sank to the bottom and the pump just wasn't strong enough to pick it up. I would think that this engine is probably doomed but who knows.
i read a couple articles a while back in chevy hi perf. mag. by mobil oil and purple oil.tight bearing clearance's are a must so your pump will need light oil to flow well.mobil in particular stressed light oil for racing along with a good pump,they're cheap compared to a roller cam set up.think about how much h.p. it takes to move that heavy oil.if you can't get to the pump to change it then i would run some internal engine cleaner that i don't recall the name of it now but most any parts store has it.beyond that all any heavy oil will do for you is cause your guage to lie to you.
current hot rod: CTS-V
I swapped the 1.5 out of a 92 Civic with a 1.6 from a 98 civic. Start to finish it took me and another guy 5 hours before we driving the car around. It's really easy, and we got the 1.6 with 46,000 miles for $500 at a junk yard, the yard even pulled the motor for us.
My honda has 275,000 on it and it's never been taken apart for work. I beat the crap out of that car and I've run 10w30 in it a few times. It didn't cause me any problems.
Discussion Starter #17
I have a local yard who has quoted me $650 for as replacement low mileage motor. I may mess with or...I may not. Just depends on what else I have going on.
I'd be happy to provide any of you a nice project car...cheap...any offers? The rest of the car is in really good shape.
wonder if putting the additive in the microwave for 30 seconds first?
1 - 20 of 20 Posts
