Hauling A55 BURNING GASS!!!
i dont knnow if i posted this before in here but i dont know the answer yet so porlly not. my oil guage reads 50 when the car is off and then when i start it and rev it up the needle moves to around 100 and thats as far as the needle goes. does this mean that my guage is off or is there a bigger problem? im using 20w 50 quaker state oil in a 350sbc
Gauge
Doc here :pimp:
Is the gauge Electric?
Electrics hold their last reported position when off...When you turn the key on without Start, it should go to zero.
If you always start off as 50 lbs when key is on, but not running, then it climbs from there, You most likely have a defective or wrong sender unit, Disconnect the sender and see if it "Zero's", that will tell you right off if it's wrong or bad.
If mechanical, replace the gauge and plumbing.
Hope it helps!
Doc :pimp:
