Hello all,
Just wanted to share with you an issue I am seeing on my SBC 283.
I am in the process of pulling the oil pan to get at the pump but thought
I'd drop a note an get some opinions.
On this particular engine when there are sustained rpms of say 4,000 for a distance of 10 miles the oil pressure starts to do crazy things. NOrmally the engine oil pressure is solid at 40PSI unless stopped at traffic light where it dips to around 20. The first time I had a problem was driving about 65 for 10 or so miles and suddenly the pressure started pushing 80 psi. I didn't think much about it other than, 'Well I have great pressure.' When I came to the next stop though, the oild pressure dropped to 5psi and I got a 'knock knock'. I pulled into a service station and discovered oil had been dumped out all over under the hood. I cleaned it up best I could, refilled it with oil and drove back home. The kicker, I didn't use a drop of oil on the way home. I have no idea what happened, but it looks like it shot out of the oil pan seal near the front of the engine. I added some sealant and tightened the pan and haven't had an issue for almost a year. I don't regularly get it out on the interstate because the car is geared low and to keep up with modern day traffic I have to run those higher rpms which I don't like to do. At any rate, last weekend I again found myself on the interstate and as per above, things got crazy again. This time the oil pressure fluctuated from 40 down to 20 back to 40, down to 30 back to 40 with the engine making an odd surging, eventually I heard what I believer was cam and lifter noise and I immediately keyed the engine off. After coasting to the shoulder I got out and inspected under the hood. No oil blown out, so I checked the oil level. Oil level was fine. I scratched my head for a minute, got back in and keyed on the car. It started fine and oil pressure was again back at a solid 40psi. I drove the rest of the way home without issue. WTF? Does this sound like an oil pressure relief valve issue or possibly a high volume pump with too small sump issue? Misplaced oil pickup? It only acts up on the interstate which like I said I get on maybe twice a year.
I plan to change the pump as a matter of course, have a look at the intermediate shaft and the pickup depth, but other than that I'm out of ideas.
I should mention my oil pressure gauge is mechanical capillary tube fitted near the dizzy.
