Well, I messed up. Putting heads and a cam on a 91' s10 with a small block in it. I was having a hard time getting the oil pump drive to align with the distributor. In a stroke of genius I put a magnet down in the hole to just be sure nothing accidentally fell down in there during assembly.
Yup, pulled the oil pump drive shaft right up and out of the engine LOL. Such a pain. I'm so used to the HV oil pumps and the steel collar on them that I just wasn't thinking. I was avoiding removing the oil pan because I don't think it's going to clear the cross member enough to get it out. I was able to squeeze the timing cover back in with just loosening the front oil pan bolts.
So, what are the odds I can install the oil pump drive shaft from the top of the engine?
