Wanted to get some thoughts on what oil to use for this application. For the past 20 years I've used nothing but Valvoline 10W30 conventional in all my SBC motors. It's worked just fine.
Now I've got this SBC 383 motor in a road race car. It's a fresh build with stock bearing clearances. Rev limiter is set to 6600 RPM but I expect to shift at 6200. So not a super high revving motor. Forged pistons, roller cam, aluminum heads. No oil cooler (yet). Very big radiator and Stewart Stage 2 pump.
I've got about 35 miles (10 laps) on the motor so far and need to do an oil change after replacing the timing cover due to a leak. My next event is at COTA on July 25th. It'll be very hot that day (over 100 degrees) and I'll have about 5 sessions of 30 minutes each.
I was thinking of switching to synthetic to better handle the heat. But then I've read that I should wait longer on the fresh build before switching to synthetic. I've also been reading that race motors can use something like 20W50. This is not a street car so I have plenty of time to let it warm up before ripping on it.
Thoughts?
Thoughts?
