1 - 7 of 7 Posts
Banned
in the top airhorn assembly of the old AFB double float carbs theres two brass jets or rods and seem to be spring loaded if you pull on them they spring back up into the air horn assembly
the ends appear to be solid and so not hollow and there seems to be some outside wear on the ends of them
so they are rods?
or are they actually supposed to be jets?
i am used to Q jet carbs that have actual jets like this in the airhorn assembly
this is the first time ive seen or touched an old AFB
very interesting with double float setup wow
yet single internal plunger accelerator pump like a q jet has
do you think napa might have a new accel pump for this?
carter 9635
thanks
I think those are called metering rods, at full vac they go down into jets and lean the mixture out and at WOT they come out of jet and richen it up. They need to work up and down freely.
so they are rods?
carter 9635
thanks
You need this!
Try some of your local book stores for this or order online from:me-books If you have been reading the posts here on a regular basis there are a lot of guys that have problems tuning an AFB/Edelbrock Performer,you can also download the Edelbrock tuning guide off their website.
Banned
ok thanks guys
so they are just rods
thats the best outcome here
other than if i can find a good or new accelerator pump for it
so i can see if the carb works good or not.
thanks
Member# 3287
Those carbs are almost foolproof. Not like a Q-jet with a bzillion moving parts and do not leak all over like a Holley.
When you buy a rebuild kit make sure it comes with the accelerator pump. Some don't.
1 - 7 of 7 Posts
