Anybody have an older Howard cam catalog. I have a flat solid grind for a small block Chev and Howards cannot seem to find the specs for it. On the back of the cam it is marked 345G and 1129. Any help will be appreciated.
Set it up in a spare block with the crank, one rod and one piston in the #1 hole. Use a timing set to connect 'em and degree the cam with a degree wheel and pointer. A steel rule and feeler gauges will help you find TDC.
