The PS pump bracket is three pieces. It attaches to the block in four places. There are two threaded studs on the front cover, a tapped hole down low on the side of the block, and a bracket that goes to the front bolt on the exhaust flange. There is a spacer that goes over the bottom threaded stud and another that goes between the side of the block and the bracket. Be sure to loosen all the bolts holding the bracket together before you try to put it on the motor. Tighten everything after all the bolts are started.
