i have an Olds 455 engine that i would like to build. i was just wondering if i could get some stock specs on it like the intake and exhaust valve dimentions, compression ratio, and the stock cam specs as in lift, duration, lobe center and overlap.
Thanks for the help.
With an Olds V-8, the only way your going to know the valve diameters is if you know what heads it has on it. What single or double number is on the left hand side of the head, example: C, K, Ka, Da, E, F, etc. sometimes even if you know the number the valve sizes can be different depending on what car it was in and VIN number.
