So................ Many...........Damn............Choices.................
Previous Set Up:
91 heavy half-ton 3.73 gears, 4x4, lifted 4"
2.5 duel in duel out exhaust, Flowmaster 40's, x pipe
ZZ4 Crate motor L98 heads unported.
ZZ4 roller cam
Lift: .474'' Int. / .501'' Exh. 208° Int / 221° Exh. @ .050'' Lift
112° Lobe Centerline RPM Range: 3500-6500
ZZ4 Chev. Per. Intake-dual plane, spread bore
Holley 670 dp truck avenger/ edel. 750 man. choke
I am LOST....
.. The 1.94/1.50 L98 heads had good low, mid torque.
What is going to be a step up head that flows better (170ish) for street fun and keep that LOW/MID TQ because i rarely run it above 5500rpm.
$+durability+reliability+functional= what head for this big truck???
Thank you! :spank:
Previous Set Up:
ZZ4 roller cam
I am LOST....
Thank you! :spank:
