Hello all, I have a 68 C10, SBC, 4L60 trans (non E). I have modified a OEM 69 auto 3 spd column to except a 4 spd over drive for the shift points in the area of top of the main mast jacket (pic #ered 1) and the lower mast jacket at the auto shift lever and the selector detent plate (pic #ered 3). I would like your feedback/opinions of the work I did will work .
Pic 1. shows where I made a relief cut (areas red circle & X) so the shift lever housing will now have room to go into first gear of the OD trans being if not cut the trans would shift from 1st and go into 2nd and hold there. The extra room now allows it to stay in 1st.
Pic2. shows the shift lever OEM fitment/placement in low/1st gear of a auto 350/400 trans.
Pic 3.shows the relief cut (red circle & arrow & X) showing the lever now has room for its 1st gear position for the 4 spd over drive.
Pic 4. shows not done yet "obviously" lol
(welded on metal piece) to have the shift lever to have a place to rest on for OD's 1st gear. My thinking if I don't weld on that additional piece of metal pad I will have to pull up on the shifter lever in Cab to get it into 2nd gear just like as you would do getting the lever out of neutral or Drive.
Pic5. is just what was explained above (I hope).
What do you think and do you think my idea will work?
Thanks ahead for any input (good or bad) you won't hurt my feelings,LOL
Marvin
Marvin
