Overheating 1940 216 cu in chevy
1640 Views 3 Replies 4 Participants Last post by  killeratrod
I am happy to be around some good intel fact group, all of the tips were correct on the overheating....the man needed to know about the prop blade position, the blades should face right , bearing is sealed so no lube, then check for loose or not turning pump, do the boiling water check on the thermostat & then check the vacuum advance....if all else then the head has some kind of blockage, seemed to not overheat before being resurfaced I think.
Ayuh,.... Is there a question in there, Somewhere,..??
I've got a 40 special deluxe w/ a 216 that's also overheating. I just had radiator redone and flushed but no luck. I'm watching ur posts and have learned a lot. I'm 19 yrs old and just learning. Thank u
hotrodkid94 you already have your own post on this.
