I am sure this question gets asked a ton, but here it goes.
I am having an issue with really only one thing and that thing is this: The PSI coming into my gun is set at 45. I pull the trigger and the gauge on my regulator at the gun inlet drops by 15psi. Now I set this to do just that with the air knob on the gun. Is this telling me that my PSI overall being sprayed with is 15psi?
I also tried this: I would pull the trigger of the gun and set the PSI at the regulator to 45PSI while it was in action, if you will. When I let off the trigger the PSI would return/rise to 60, because of the air knob being set for 15psi.
Which is the right way or am I way off?
The problem I am getting for the most part is when I try to adjust my gun settings I keep losing my spray width. I am trying to achieve around an 8" spray pattern.
I have sprayed before with BC/CC and had the same issue and learned from that due to spraying to heavy of a paint job and clear, which turned into pinning later from lack of solvent coming out properly.
I am stepping up to metallic now on two cars I am painting this week and want to not have that happen again. I do not want to be sanding that much again. The jobs came out nice, but it was a lot of extra work that is not really welcomed this time.
Any and all tips for tuning the gun better than I have in the past would be great. I do not want to kill my new paint job on my 67 GTO Convertible this time around.
I will attach a pic as soon as it lets me, I had one posted in this edit but it disappeared and now I can't.
Thank you,
Thank you,
