"thanks for the information. I have one more question. I have a harbor freight bottom feed spray gun for my epoxy primer, and primer filler. I have a Itawa 400 HVLP for my base coat and clear. My question is which gun do I need to use to spray the primer sealer? Primer gun has 1.7 tip and BC CC has a 1.3 tip."
Either gun will work although some people would choose not to spray any primer or sealer through their clear gun. If it were me I'd use the HF gun for the sealer, but then again if it were me I would not bother with sealer if I had already primed the block with epoxy. I like to use a thinned (10%) epoxy as sealer and on a casting that is not all that smooth I probably wouldn't even bother thinning the epoxy. Prime with epoxy let set overnight and then spray base and clear. If you are planning on a urethane primer to fill and smooth some of the casting you still really don't need sealer as long as the primer is a uniform color. My 2 cents...
