I am getting ready to paint my '68 VW Bug Convertible and I have a few unanswered questions. This is my first paint job and I really want to have a good result, so I've been doing a lot of reading.
As for my equipment, I inherited a small compressor (20gal 5hp) and a Campbell Hausfeld siphon style gun which seemed to work okay for the primer. To be honest, I need some help with gun set-up too. When I shot the primer I set my PSI at the gun at 40psi and set the adjustments until I had a cigar shaped pattern and the dropletts were as fine as I could get them. I'm spraying in my garage which has been retro-fitted with a make-shift paint booth per instructions on this site (Thank you). This set-up worked good thus far, but I am worried that the paint will be much more difficult to apply and I may need to get some new equipment.
I started with all of the major body work and sanding, I did a really good job of cleaning it with a dish soap and then wiped it thoroughly with a tack cloth and just shot a coat of "Cross-Fire" self-etching primer on it. (Napa Brand) Now, I still have a few areas of the body that need some more working and was wondering, should I try to straighten these areas first or shoot my primer/filler next?
I plan to use an Acrylic Enamel paint and I think I will need to use a two-stage system. My question here is, can I use PPG or DuPont products over my Napa self-etching primer? If not I will stay with the same brand, but I am worried about yellowing clearcoats since the main color will be white (I've heard that many low-budget clears will yellow). The main reason I would like to use a two-stage is because I would like to add some pearlescent ghost-flames as well and I have read that these look best when a two-stage is used, also I hear two-stage is a little more forgiving to apply.
Any help with this will be greatly appreciated!!!
