1 - 6 of 6 Posts
im on a highway to hell
i have a stainless steel tub with a hinged cover and a center drain at the bottom, i'm going to make it a parts washer, i already have a pump the question is do i need some type of gasket or rubber molding around the top to keep fumes in ? and if i do what type of rubber or foam do you yhink i should use? thanks for your help.:cool:
No rubber gasket will last if you get a potent cleaning solution in the tank. Are you going to heat the cleaning solution? I keep my hot tank in a shed outside the main working area. The fumes from the hot solution can get intense..
no i wasn't planning on heating it up. what do they put on the parts tanks you buy? iv'e never looked and i'm not near one.
Get saturdays paper and look for used dishwasher - usually $25-$35. Give it a shot of Simple Green or your favorite... and let it rock. Don't use the one in you kitchen!
49 T&C
1 - 6 of 6 Posts
