Where should I have the PCV valve hooked up to? It's on a '66 Pontiac Catalina 389 with a 4-barrel and a edelbrrock intake. Right now it is hooked up to a manifold vacuum port.
The PCV on his goes to something on theblock right next to the distributor.docvette said:Doc hereimp:
The other end of the PCV Valve goes into your Valve Cover or if so equipped, your oil filler tube (50's and 60's typical)
Be sure you have a positive breather Cap (S), and if so equipped, remove the road draft tube and plug the hole with a rubber expansion plug.
Docimp:
